15 years agoVHDL std_logic_vector Comparisons
What's the best way to compare std_logic_vector 's to zero in VHDL? I don't want to use conversion functions, create a std_logic_vector of "0"s, or do element-by-element comparisons.
15 years ago --- Quote Start --- Sure - you can even have record types on the entity. One problem with integers could mask initialization problems when comparing gate-level simulations with RTL: there is no "X" value for integers. So I try to stick to slv. --- Quote End --- True, but if you are not too concerned with gate level simulation, there is no worry. Use any type you want for any ports, but at the top level, use a bit-array type, or record of bit array types so you can map each bit to individual pins.
