VHDl spi adc example
- 3 years ago
Hi Tex,
Max 10 ADC are line-in ADC. Usually Modular ADC Core IP is used for that. Check these two links http://gogofpga.blog.fc2.com/blog-entry-182.html and https://www.youtube.com/watch?v=0oO1RFa-4Xk&t=1s
The SPI RTL design example can be found had been shared to you before. Can't find any VHDL one. Btw, the design store example design https://www.intel.com/content/www/us/en/design-example/715016/max-10-serial-peripheral-interface-master-an-485.html I had been tested on DE-10 Standard (Cyclone V) ADC since Max 10 ADC are line-in ADC. Check the attached design folder and STP waveform. The function as below:
Control Register Write: CS high, WR high
Transmit through MOSI: CS high, WR high, addr "10"
Status Register Read: CS high, RD high, addr "01"
Received (MISO) to data_bus: CS high, RD high, addr "11"
Sheng
Hi Tex,
Sheng
Thank you sheng this helped me alot..
