15 years ago
vhdl querry
Dear Friends,
I have been studying a code --
write_req <= fifo_i_addr_wren and u_cmd(1);
p_data_req:process(phy_clk)
begin
if rising_edge(phy_clk) then
if reset_phy_clk = '1' then
write_req_1 <= '0';
write_req_2 <= '0';
else
write_req_1 <= write_req;
write_req_2 <= write_req_1;
end if;
end if;
end process p_data_req;
data_req <= write_req_2;
In this code the data_req is a delayed (2 clock cycles) of write_req.
I tried to understand this code - How is this delayed by 2 clock cycles? I am a conventional C coder. This is for delay of 2 cycles. If i use the same logiccc can I do for > 2 delays? How is this executed? I know that the process if-else is executed sequentially.
Can anyone explain the logic here? How is this implemented in hardware? Is it done using a mux ? How does this work out then pls?
Vinod.
    --- Quote Start ---
    --- Quote End ---
    Maybe your conventional C programming experience is misleading you.
    Please note the the following assignments
    DON'T behave as in conventional C, where you would obtain write_req = write_req_1 = write_req_2 in the end. Actually the <= assignments are performed in parallel once when the process is triggered (in your case on the clock rising edge).
    Then the second line will assign to write_req_2 the original status of write_req_1. In other words, you can change the order of the two lines without changing the result.
    This code is usually synthesized with 2 chained flip-flops, but in general the implementation of more complex code will depend on the tools you are using, like C code would result in different assembler instructions depending on compiler and optimization level.
    --- Quote Start ---
    --- Quote End ---
    A VHDL text book or tutorial would be helpful, I think.
    Generally, an assignment in a sequential edge sensitive process (e.g. using if rising_edge()) generates registers. The two cycle delay is generated by chaining two registers. If you want a longer delay, use more registers. For your convenience they can be arranged as a bit vector shifted one position on each clock.
