15 years agovhdl querry
Dear Friends, I have been studying a code -- write_req <= fifo_i_addr_wren and u_cmd(1); p_data_req:process(phy_clk) begin if rising_edge(phy_clk) then if rese...
15 years ago --- Quote Start --- I tried to understand this code - How is this delayed by 2 clock cycles? I am a conventional C coder. This is for delay of 2 cycles. If i use the same logiccc can I do for > 2 delays? How is this executed? I know that the process if-else is executed sequentially. --- Quote End --- Maybe your conventional C programming experience is misleading you. Please note the the following assignments write_req_1 <= write_req; write_req_2 <= write_req_1; DON'T behave as in conventional C, where you would obtain write_req = write_req_1 = write_req_2 in the end. Actually the <= assignments are performed in parallel once when the process is triggered (in your case on the clock rising edge). Then the second line will assign to write_req_2 the original status of write_req_1. In other words, you can change the order of the two lines without changing the result. This code is usually synthesized with 2 chained flip-flops, but in general the implementation of more complex code will depend on the tools you are using, like C code would result in different assembler instructions depending on compiler and optimization level. Regards
