14 years ago[VHDL] integer to std_logic or std_logic_vector conversion
Hello, I've some issues to convert integer to std_logic or std_logic_vector. I need to do so for a testbench which reads stimuli (binary or positive integers) in a text file, stores it as intege...
14 years agobtw, what are you trying to compile this code in? You cannot compile this code in Quartus, which is probably why you're getting a range constraint violation, because Quartus wants to map integers to 32 bits, and you only asked for 1 bit. (As well as non of the textio stuff being appropriate).
The first line should work fine in Modelsim.
