15 years agoVHDL Error (10028): Can't resolve multiple constant drivers for net...
Hi all, I'm a rank beginner, so expect beginner errors. I am using Quartus v9.1. I'm getting the famous "Error (10028): Can't resolve multiple constant drivers for net "button1" at keyfob...
15 years agoYou should think of a procedure (or function) to be executed 'in-line' i.e. inside the process where you make the call to it. So you end up with two processes assigning a value to the signal 'button1', hence the compiler's complaint. The same applies to signal ' button1_bits_left'.
To solve this in your code you have to change the approach to handle every assignment to signal 'button1' in a single process. The simplest approach is to handle everything in the clocked process.
