14 years ago[VHDL] Different synthesis results after using "generate"
Hello, I used 'generate' statement to order several similar components, but after that synthesis results are slightly different. Does anyone know what can cause this? Theoretically there is no d...
14 years agoThe generate statement should be identical to the above code.
But a different random seed for the fitter may have been used, which can affect the timing. Resource usage should be the same.
