14 years ago[VHDL] Different synthesis results after using "generate"
Hello, I used 'generate' statement to order several similar components, but after that synthesis results are slightly different. Does anyone know what can cause this? Theoretically there is no d...
14 years agoThanks for replies. By "results" I mean resource utilisation and timing analysis results.
I have a FIR filter with a chain of 8 MAC modules: --- Quote Start --- mac0 : mac port map ( aclr0 => mac_rst, clock0 => clk, dataa => sample(0), datab => coeff(0), overflow => of(0), result => sum(0) );. . . mac7 : mac port map ( aclr0 => mac_rst, clock0 => clk, dataa => sample(7), datab => coeff(7), overflow => of(7), result => sum(7) ); --- Quote End --- Sample, coeff and sum are arrays of vectors. Instead, I wrote it like this: --- Quote Start --- mac_components : for i in 0 to 7 generate begin macs : component mac port map(mac_rst, clk, sample(i), coeff(i), of(i), sum(i)); [/INDENT]end generate mac_components; --- Quote End --- I'm not sure about this change because, according to TQ, timing results are a bit worse (but still within margin). Should I be so careful with this type of code?
