15 years agoVHDL_Debugging help
I'm trying to write some VHDL code for a 3 to 8 decoder, but I get the same error all the time what is wrong with my code, I have also attached a screen shot of the program and errors.
library IEEE; use IEEE.std_logic_1164.all; ENTITY 3to8decoder IS PORT ( A,B,C :IN std_logic; Y :OUT std_logic_vector (7 DOWNTO 0)); END 3to8decoder; ARCHITECTURE decoder_C OF 3to8decoder IS signal ABC: std_logic_vector(2 DOWNTO 0); BEGIN ABC <= A & B & C; WITH ABC select Y <= “00000001” WHEN “000”, “00000010” WHEN “001”, “00000100” WHEN “010”, “00001000” WHEN “011”, “00010000” WHEN “100”, “00100000” WHEN “101”, “01000000” WHEN “110”, “10000000” WHEN other;-----> the error is here it says there is a syntax error. END decoder_C; Thank you Heath4 Replies
single quotes is for single characters
double quotes is for strings - Altera_Forum
you should keep double quotes as original ones
I'm still getting errors I changed all the double " to single, and got less errors, stille getting 4 thow.
library IEEE; use IEEE.std_logic_1164.all; ENTITY decoder3to8 IS PORT ( A,B,C :IN std_logic; Y :OUT std_logic_vector (7 DOWNTO 0)); END decoder3to8; ARCHITECTURE decoder_C OF decoder3to8 IS signal ABC: std_logic_vector(2 DOWNTO 0); BEGIN ABC <= A & B & C; WITH ABC select Y <= '00000001' WHEN '000', --here is the error and line:Error (10500): VHDL syntax error at 3to8decoder.vhd(14) near text "'"; expecting "(", or an identifier, or unary operator '00000010' WHEN '001', '00000100' WHEN '010', '00001000' WHEN '011', '00010000' WHEN '100', '00100000' WHEN '101', '01000000' WHEN '110', '10000000' WHEN others; END decoder_C; - Altera_Forum
write:
when others; instead of when other;
