15 years agoVHDL Code Of 2 input XOR -gate
I am new to VHDL programing and i had written a VHDL code on 2 input XOR gate using process and it compiles successfully but in test bench waveform i am unable to get the output that is for all possible inputs i am getting 0 output , I am using Xilinx 9.1 and the following is code entity XOR2 is Port ( A : in STD_LOGIC; B : in STD_LOGIC; C : out STD_LOGIC); end XOR2; architecture Behavioral of XOR2 is begin process(A,B) begin if((A='0') and (B='1')) then C<='1'; elsif((A='1') and (B='0')) then C<='1'; else C<='0'; end if; end process; end Behavioral;3 Replies
Your process looks ok to me
though you can simplify it to:
either way it should work. Change the entity name to something other than xor2 just in case. Otherwise there is some thing wrong with your observation.process(A,B) begin if (A = '1' and B = '0') or (A = '0' and B = '1') then C <= '1'; else C <= '0'; end if; end process; - Altera_Forum
hi
Thanks for information but i want to implement it with process so is it possible - Altera_Forum
You can just use the inbuilt function xor(without process)
C <= A xor B; I wonder if your entity name xor2 is legal since I think there is an inbuilt vhdl function in that name.
