14 years agoVHDL code for PC-FPGA connection
Hi to everyone,
I want to connect my PC with the FPGA with a fast connection using low-level codes. That is, I don't want to use NIOS processor since I have my own data-mining oriented blocks and I need all the FPGA Logic Elements as possible for this task. The problem is that I have to transfer Gigabytes of information from the PC to the FPGA in reasonable times. I though to use an ethernet connection for this or maybe an USB connection but I need low-level codes for this task. How can I get these codes (in VHDL format as an example)?. In fact probably this is a common problem for FPGA users. Can anyone help me with this? Thank you! Josep Lluís from Spain.1 Reply
This still has Nios II in it but it's there to do control type stuff and not in the actual data path: http://www.alterawiki.com/wiki/nios_ii_udp_offload_example
If I remember correctly that design exposes 1-4 TX and 1-4 RX ports that can swamp a 1Gbps link.
