16 years ago
Vhdl code for IP_IRQ component!
Hi, I need help for Vhdl code for designing one IP component, small device drivers and test demonstration that give a periodic interrupt to sierra every second.
"SEE ATTACHMENT"
Component level interface (VHDL) is:
PORT (
addr : IN std_logic_vector(1 downto 0);
clk : IN std_logic;
cs_n : IN std_logic;
read_n : IN std_logic;
din : IN std_logic_vector(31 DOWNTO 0);
reset_n : IN std_logic;
write_n : IN std_logic;
dout : OUT std_logic_vector(31 DOWNTO 0);
irq_out_n : out std_logic_vector(1 downto 0) ) ;
END;
I attached also a vhdl code(IP_IRQ) that i wrote but is not working. I don’t know what’s wrong.
    a couple of things:
    dont use std_logic_unsigned/signed/arith at the same time as ieee.numeric_std. I recommend using numeric_std.
    you cant compare a std_logic vector to a integer literal, you have to compare it to a string. For a hex string you need to write x"5e7". A std_logic_vector is NOT an integer, its a collection of bits.
    --- Quote Start ---
    "SEE ATTACHMENT"
    PORT (
    clk : IN std_logic;
    END;
    --- Quote End ---
    can you describe your problem a little bit more ? I could see at least one problem.
    irq_out_n(1) is only set in the reset branch. I would assume that Quartus would
    generate a latch for irq_out_n(1).
    Kind regards
    GPK
