16 years agoVhdl code for IP_IRQ component!
Hi, I need help for Vhdl code for designing one IP component, small device drivers and test demonstration that give a periodic interrupt to sierra every second. "SEE ATTACHMENT" Com...
16 years ago --- Quote Start --- Hi, I need help for Vhdl code for designing one IP component, small device drivers and test demonstration that give a periodic interrupt to sierra every second. "SEE ATTACHMENT" Component level interface (VHDL) is: PORT ( addr : IN std_logic_vector(1 downto 0); clk : IN std_logic; cs_n : IN std_logic; read_n : IN std_logic; din : IN std_logic_vector(31 DOWNTO 0); reset_n : IN std_logic; write_n : IN std_logic; dout : OUT std_logic_vector(31 DOWNTO 0); irq_out_n : out std_logic_vector(1 downto 0) ) ; END; I attached also a vhdl code(IP_IRQ) that i wrote but is not working. I don’t know what’s wrong. --- Quote End --- Hi, can you describe your problem a little bit more ? I could see at least one problem. irq_out_n(1) is only set in the reset branch. I would assume that Quartus would generate a latch for irq_out_n(1). Kind regards GPK
