17 years agovhdl code error
hi i am getting an error of Can't infer register for "bbpa[0]" at spim2.vhd(127) because it does not hold its value outside the clock edge while compiling the following code entity sp...
17 years agoRepost with some carrige returns/line feeds please!
One potential problem I can see though - you are using buffers for the block IO. Hardly anyone uses these anymore - stick to in/out (or if at top level inout if you must!)
