10 years agoVHDL code cosimulation using Altera Modelsim starter edition
Hello, I have generated a VHDL code from my MATLAB R 2015a Simulink model. I have also generated a HDL cosimulation model to test the code using Modelsim Altera Starter Edition. However, when I...
10 years agoThe FLI is supported in both ModelSim PE and SE. I believe in the past you also had to buy a simulink license from Mathworks in order to use this capability, but not sure if this is still true.
@Tricky: I believe PE stands for Personal Edition
