16 years agoVHDL and SOPC together
Hello, i'm currently working on cyclone III (ep3c120f780c7n) development board and try to do something without any idea on how to realize it i made working the following project "cycloneIII_3c12...
16 years agoHello,
1> Regarding loading the Camera Pixel Data to DDR: You can add a custom module, It has to do the following a) takes input from the camera sensor, b)write it into a fifo wrt to camera_clk and then read from the fifo wrt[with respect to] ddr_clk c) Then write it to the ddr by designing a simple avalon bus interface that supports the DMA component already available in the SOPC builder in VHDL/verilog DMA component is instanced to your design in the SOPC along with the custom component [above explained] you designed. Regards, Jagadeesh.B
