17 years agoVhdl Alu
It is possible to create an ALU that add, subtracts and multiplies all in one? I cannot seem to get the multiplication to work because I need double the storage because the numbers are being multiplied. Do I just need to use different storage variables? Is there a "cleaner" way?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
ENTITY ALU IS
port(x, y : in std_logic_vector(7 downto 0); --variables on which opeation is performed
operation : in std_logic_vector(2 downto 0); --how to choose what operation
zero : out std_logic;
result : out std_logic_vector(7 downto 0));
END ALU;
architecture ALU_ARCH of ALU is
begin
process(operation)
variable temp: std_logic_vector(7 downto 0);
begin
case operation is
when "101" =>
temp := x + y;
when "110" =>
temp := x - y;
when "111" =>
temp:=x*y;
when others =>
temp := x - y;
end case;
result <= temp;
end process;
end ALU_ARCH;
if you sum a number of 8 bits with another number of 8 bits the result may have 9 bits but your variable "temp" has only 8 bits! Eg: 1111 1111 + 1111 1111 = 1 1111 1110 I think he said this! - Altera_Forum
what do you mean by "carriers"?
Make result and temp 16 bit wide. Your ALU is not working properly in case of carries already, anyway.
