16 years agovhdl addition result size
Hello, maybe a dummy question: I am using arith package. If I need to add 2 signed std_logic_vector of 3 bits, The output should be a std_logic_vector of 4 bits, 3+3=6 ----->...
12 years ago --- Quote Start --- result <= resize(s1_16bits + s2_16bits , 17); doesn't do what expected : the carry will be forgotten and result(17) always '0' (for unsgined) --- Quote End --- Essentially a wrong expectation. The 16 bit numbers are added first, with 16 bit result size according to VHDL rules, unfortunately involving a possible overflow. Then sign extended after the overflow occurred. For the expected result, you need to sign extend first, then add.
result <= resize(s1_16bits , 17) + s2_16bits;
