16 years agoVHDL adding two registers
I am trying to add two registers together so that A=A+B. The code I have compiles, but when I simulate, I do not get the expected result. Can someone help me?
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_arith.all;
Use ieee.std_logic_unsigned.all;
Entity Four_Bit_Register is
Port (
Clear : in std_logic;
Inc : in std_logic; -- x
Clock : in std_logic;
Cnt_in : in std_logic_vector(3 downto 0);
Cnt_out : out std_logic_vector(3 downto 0);
Load : in std_logic);
End Four_Bit_Register;
Architecture Four_Bit_Register_Arch of Four_Bit_Register is
Signal Cnt,A,B : std_logic_vector (3 downto 0);
Begin
Cnt_out <= Cnt;
Count : Process( Clear, Inc, Clock, Load)
Begin
if clock'event and Clock = '1' then
A<=A+B;
if Clear = '1' then
Cnt <= "0000";
elsif Load = '1' then
Cnt <= Cnt_in;
elsif Inc= '1' then
Cnt <= Cnt + "0001";
else
Cnt <= Cnt;
End if;
End if;
End process;
end Four_Bit_Register_Arch;
