--- Quote Start --- if you want to do division of any significant bitwidth (>3~4 bits num and den), you need to instantiate the divider megafunction --- Quote End --- Cyclone III achieves > 50 MHz for a 8:8 Bit signed and > 40 MHz for a 12:8 Bit unsigned divider (between registers). This is at least a significant bitwidth at reasonable clock frequency, I think. If you want more, you need divider internal pipelining and the alt_div MegaFunction. - Altera_Forum
you can try adding some extra registers and turning on register retiming, but lpm_divide seems to have significantly better performance.
--- Quote Start --- you can try adding some extra registers and turning on register retiming --- Quote End --- Sounds like poor mans pipelining, but an interesting suggestion though. Seriously, if the infered divider doesn't achieve the intended speed, you should use an explicite instantiation. - Altera_Forum
--- Quote Start --- It does, under the conditions I told. (Valid at least for V9.0 and later). --- Quote End --- If i use version 9 or later will it accept the division . i have not yet used version 9. - Altera_Forum
Divider interference works with previous Quartus versions as well, I checked V6.0 and V8.1. I guess, you ignored the other points that have been said in the above discussion.
Or the best solution is to redesign the algorithm so that you dont have to do the divide in the first place - stick to multiplies instead.
a/b = a * 1/b. Do the 1/b function on something else (like a processor) if you can. - Altera_Forum
--- Quote Start --- Or the best solution is to redesign the algorithm so that you dont have to do the divide in the first place - stick to multiplies instead. a/b = a * 1/b. Do the 1/b function on something else (like a processor) if you can. --- Quote End --- but 1/b also has a division then how can it accept?. or how to do it - Altera_Forum
--- Quote Start --- but 1/b also has a division then how can it accept?. or how to do it --- Quote End --- Hence why I said take it off FPGA onto something like a processor. Division can be done fine on an FPGA, it just eats through resources. - Altera_Forum
If speed is not important you could fall back on a serial divider mechanism, doing 'long division' in binary.
--- Quote Start --- Sounds like poor mans pipelining, but an interesting suggestion though. --- Quote End --- if by poor you mean lazy, certainly. :) it would be nice if register retiming could meet the fmax of an lpm function. i haven't found it to do so with wide multipliers (24 bit) in CIII either.
