14 years agoVHDL -> Verilog for loop conversion
I have been attempting to convert some code I have written from VHDL to Verilog without much success. My main stumbling block is the for loops in my VHDL code. My FOR loops have a much larger index...
14 years agoFirst comment, for(i=0;i<1;i=i+1) is evaluating the following code only once (for i = 0), not the same thing that the VHDL equivalent does.
Secondly, the "range" select problem can be solved in Verilog by a construct called indexed part select, see an example from Std IEEE 1364, particularly the last line:reg big_vect;
reg little_vect;
reg dword;
integer sel;
big_vect // == big_vect
little_vect // == little_vect
dword // variable part-select with fixed width The basic solution working without "advanced" Verilog syntax, that's possibly missing from a "Verilog for beginners" tutorial, is using nested loops. Although VHDL to Verilog translation by trial-and-error method will work somehow, it's possibly less frustrating with a profound Verilog text book at hand.
