15 years agoVGA output
hi guys, im quite new into using VHDL language.. i have cyclone II de1 altera board and i want to know how i can output an image to the VGA port.. thanks.. sample codes would be really helpful....
15 years ago --- Quote Start --- hi guys, im quite new into using VHDL language.. i have cyclone II de1 altera board and i want to know how i can output an image to the VGA port.. thanks.. sample codes would be really helpful.. :D --- Quote End --- You need to understand VGA timing, how "new" are you to VHDL? Anyway, the DE1 User's manual has a section on VGA timing. You basically need to generate those signals. Here is more information for higher resolutions: http://tinyvga.com/vga-timing Good luck. Bart
