17 years agoVGA 25MHz, Clock 100MHz, Help!
Hi, I would like to use a 100MHz clock to drive my logic, but the problem is that VGA needs a clock of 25MHz. Right now, I am using 2 PLLs to create a 100MHz clock and 25MHz clock by us...
17 years agoHere is a vga example with a reduced pixel clock (should run at 100MHz for 25MHz Pixelclock)
If you need other resolution, just modify some counters and fixed values. //*************************************************************************************************************************************************** // definitions, includes //====================== // synthesis translate_off `timescale 1ns / 1ps // synthesis translate_on module video_vga_lcd_640x480 ( gls_clk, reset_n, nHSync, nVSync, HBlank, VBlank, Red, Green, Blue, ActiveArea, XPixel, YPixel ); input gls_clk; input reset_n; output nHSync; output nVSync; output HBlank; output VBlank; output Red; output Green; output Blue; output ActiveArea; output [ 9: 0] XPixel; output [ 9: 0] YPixel; reg [1:0] slowdown4to1; always @ (posedge gls_clk) slowdown4to1 <= slowdown4to1 + 2'd1; wire EnablePixelClk; assign EnablePixelClk = !slowdown4to1; // Horizontal // 640 Pixel // 48 Front Porch // 96 Sync // 16 Back Porch // 800 Pixel pro Zeile reg [ 9: 0] XPixel; always @ (posedge gls_clk) if ( XPixel === 10'd799 ) XPixel <= 10'd0; else XPixel <= ( EnablePixelClk ) ? XPixel + 10'd1 : XPixel; reg HBlank; always @ ( posedge gls_clk ) if ( XPixel === 10'd639 ) // Start of Front Porch HBlank <= 1'b1; else if ( XPixel === 10'd799 ) // End of Back Porch HBlank <= 1'b0; else HBlank <= HBlank; reg nHSync; // 640 -1 + 16 till 640 - 1 + 96 always @ ( posedge gls_clk ) if ( XPixel === 10'd655 ) // Start of HSync nHSync <= 1'b0; else if ( XPixel === 10'd735 ) // End of HSync nHSync <= 1'b1; else nHSync <= nHSync; // Vertikal // 480 Videolines // 10 Front Porch // 2 Sync // 33 Back Porch // 525 Lines total reg [ 9: 0] YPixel; always @ ( posedge gls_clk ) if ( XPixel === 10'd799 ) if ( YPixel === 10'd524 ) YPixel <=10'd0; else YPixel <= YPixel + 10'd1; else YPixel <= YPixel; reg VBlank; always @ ( posedge gls_clk ) if ( XPixel === 10'd799 ) if ( YPixel === 10'd479 ) // Start of Front Porch VBlank <= 1'b1; else if ( YPixel === 10'd524 ) // End of Back Porch VBlank <= 1'b0; else VBlank <= VBlank; else VBlank <= VBlank; reg nVSync; // 480 - 1 + 10 till 480 - 1 + 10 + 2 always @ ( posedge gls_clk ) if ( XPixel === 10'd799 ) if ( YPixel === 10'd489 ) // Start of VSync nVSync <= 1'b0; else if ( YPixel === 10'd491 ) // End of VSync nVSync <= 1'b1; else nVSync <= nVSync; else nVSync <= nVSync; wire ActiveArea; assign ActiveArea = !HBlank && !VBlank; wire Red; assign Red = ActiveArea && XPixel[2]; wire Green; assign Green = ActiveArea && XPixel[5]; wire Blue; assign Blue = ActiveArea && XPixel[8]; endmodule
