17 years agoVerilog Language to desribe top entity
I used a DE2_NIOS project in the Altera CD , and modify(delete some unnecessary modules , and add some pio modules ) it properly to be used as a uclinux project. Modification is ONLY done in the S...
17 years ago --- Quote Start --- ¿did you keep the timer module?. ¿doe's a simple Nios II IDE project run on your system? --- Quote End --- Maybe I should re-modify the project in QuartusII, reassign the pins of the project. And the sof file may have its effect , uclinux system can run with it.
