17 years agoVerilog Language to desribe top entity
I used a DE2_NIOS project in the Altera CD , and modify(delete some unnecessary modules , and add some pio modules ) it properly to be used as a uclinux project. Modification is ONLY done in the S...
17 years ago¿did you keep the timer module?.
¿doe's a simple Nios II IDE project run on your system?
