17 years agoVerilog Compiliation Error
Hi, I am trying to implement a scaling function for the FFT Megacore Function. I copied and modified the Verlilog code from http://www.altera.com/literature/an/an404.pdf. My modified code is at...
17 years ago --- Quote Start --- Apologies, I didn't use Megawizard at all. I just used a block tool and created a design file from the block. There's nothing else on the board except that function. As you adviced, I have included the function to work on the positive clock edge. yeah, i know the code given is only an example, but that's exactly what i'm trying to do. just a simple scaling function. Didn't think i'd run into this much problems...:( --- Quote End --- Hi , can you post the file "test_scaling", where you use the scaling block as an instance ? Kind regards GPK
