17 years agoVerilog Compiliation Error
Hi, I am trying to implement a scaling function for the FFT Megacore Function. I copied and modified the Verlilog code from http://www.altera.com/literature/an/an404.pdf. My modified code is at...
17 years ago --- Quote Start --- Hi, I am also using Quartus 9.0 SP2 but it still comes up as "Can't synthesize current design -- Top partition does not contain any logic". How do I find out my toplevel? Sorry, i'm pretty new to this stuff. No, not all the code was generated by Megawizard, only the inputs and outputs. The rest are from a website provided by Altera (http://www.altera.com/literature/an/an404.pdf) (http://www.altera.com/literature/an/an404.pdf) Thanks for your response. --- Quote End --- Hi. why do you generate only the ports with the Megawizard? I think the code in the application note is only an example to show how it works. Can you post your Quartus project as a tar-file in the forum ? Kind regards GPK
