14 years ago
Verilog array assistance
Hello all, I'm attempting to copy a portion of a 128 byte array to a 32 byte array. I'm using one of a possible five 7-bit Addresses to determine the start and end point.
Here are my declarations:
--- Quote Start ---
reg [7:0] STORAGE_BUF0 [31:0];
reg [7:0] LARGE_ARRAY[127:0];
reg [6:0] ADDR [5:0];
--- Quote End ---
Here's where the assignment takes place:
--- Quote Start ---
STORAGE_BUF0[31:0] <= LARGE_ARRAY [(ADDR[0]+7'd32): (ADDR[0]+7'd01)];
--- Quote End ---
The errors I get are:
Error (10133): Verilog HDL Expression error at XX: illegal part select of unpacked array "STORAGE_BUF0"
Error (10734): Verilog HDL error at XX: ADDR is not a constant
Error (10133): Verilog HDL Expression error at XX: illegal part select of unpacked array "LARGE_ARRAY"
Can anyone tell me where I'm messing up?
Thanks in advance!
    Makes sense.
    I've got it implemented and everything seems happy.
    Thanks for your help!
    That is correct. So you can't have a variable number of loops. Needs to be constant. Otherwise it would be impossible to implement in hardware.
    Ah, okay.
    This means the 'i' index can't be dependent on anything else, correct?
    The for loop will be unrolled and implemented. this of course means that the index variable in the for loop can't be variable.
    I'm trying that now.
    Do you know how a for loop synthesizes in hardware?
    Crap, I don't know what I was thinking. I know you can't copy a 2D array like this!
    So, is there a faster way than setting up a loop for 32 clock ticks and copying it one byte at a time?
