12 years agoVerifying Sampled Data in FPGA ?
Hi, Is there any way to verify the sampled data in FPGA ? I can see clock and some data in SignalTap but just don't know how to verify if ADC is sampling correctly ? Any way to plot the data in...
12 years ago --- Quote Start --- Is there any way to verify the sampled data in FPGA ? I can see clock and some data in SignalTap but just don't know how to verify if ADC is sampling correctly ? Any way to plot the data inside FPGA or exporting data to text file ? I really appreciate your help. --- Quote End --- SignalTap II can be accessed from MATLAB, so you can use that to access data captures. You can also create a design where you capture blocks of data to on-chip RAM or SDRAM, and then read the data capture onto your PC and analyze the data. Read this DSP tutorial and look at the code; http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104code_hawkins.zip What board are you using? Cheers. Dave
