16 years agoVerify failed between address 0x80020 and 0x85ed7(address is sram)
Hi everybody! My new board has a sram on it,but when i run nios_cpu in it. NiosIDE show me that something wrong with sram,the information like as title, the 0x80020 is reset address,point to s...
16 years agoI assume you meant 512kbytes.
The address bus would be 19 bits if the memory data bus were only 8 bits. As your chip is 16 bits wide, the low significant bit of the address bus isn't used, and the other 18 are connected to the memory chip.
