16 years agoVerify failed between address 0x80020 and 0x85ed7(address is sram)
Hi everybody! My new board has a sram on it,but when i run nios_cpu in it. NiosIDE show me that something wrong with sram,the information like as title, the 0x80020 is reset address,point to s...
16 years agoFrom the Nios IDE, create a new project with the "Memory test" template. Configure the system library so that everything is put in the on-chip RAM (using the smaller standard library if needed) and compile it.
Then run the application, and it will ask you for a memory address to run the test. Give it the address of your sram and check if it finds anything.
