17 years agoVerify failed between address 0x2000000 and 0x200FFFF
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 02000000 ( 0%) Downloading 02010000 (...
15 years ago --- Quote Start --- hi, may i know what do you mean by changing the pins? i dont understand. i am having the same problem with sdram. --- Quote End --- Hi. You need change in Pin Planner: DRAM_LDQM to DRAM_DQM[0] DRAM_UDQM to DRAM_DQM[1] and DRAM_BA_0 to DRAM_BA[0] DRAM_BA_1 to DRAM_BA[1] And then, you can assign these pins to your Nios II as buses. DRAM_DQM[1..0] DRAM_BA[1..0] You must do this because Nios II in SOPC Builder 9.1 SP2 has buses for these connections to the SDRAM I hope to be clear enough :)
