17 years agoVerify failed between address 0x2000000 and 0x200FFFF
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 02000000 ( 0%) Downloading 02010000 (...
15 years agoI had the same problem.
I was using DE2 board, and the problem was with sdram pins. I had to change manually DRAM_BA pins and DRAM_DQM pins. After that fix, the proyect works properly.
