17 years agoVerify failed between address 0x2000000 and 0x200FFFF
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloading 02000000 ( 0%) Downloading 02010000 (...
17 years agothis can be due to a lot of reasons.
if you use sdram f.e. check the phase of the sdram clock. have you tried a simple hello world with a minimal system running from internal memories instead of external memory ?
