11 years agoVCC_ONE setting in QII 14.0
Hi, I'm looking for solution how to set the VCC_ONE of Max 10 device in QII14.0. I would like to set the VCC_ONE to 3.3V but after compilation, it showed that VCC_ONE is 3.0V. Can anyone ...
9 years agoThen, I suspect, the original bug is still present in Q17. Raise a ticket via myaltera (https://www.altera.com/mal-all/mal-signin.html).
However, for the purposes of analysing the power consumption, I suspect you can make some considered judgement as to what the increase in power would be when running at 3.3V, as compared to 3.0V, based on the numbers coming from the power play analysis. Cheers, Alex
