15 years agoUsing WM8731 Codec on DE2 board as an ADC
I'm using the WM8731 Codec on the DE2 board as an ADC by taking in audio from the Line In jack and sampling it at 48KHz. I've got a project setup to do this using code supplied by Altera/Terasic and...
13 years agohi dp800, i saw your post, did you done the audio codec configuration? can i share your verilog code? just want to refer from you. i won't copy your code. i am doing a project about audio codec, really need your help. your help will be appreciate. thanks you~
