15 years agoUsing WM8731 Codec on DE2 board as an ADC
I'm using the WM8731 Codec on the DE2 board as an ADC by taking in audio from the Line In jack and sampling it at 48KHz. I've got a project setup to do this using code supplied by Altera/Terasic and...
14 years agoHi HJ.C,
I think if you are beginner it's very hard to do this stuff all on your own. May be this helps: http://users.ece.gatech.edu/~hamblen/de2/ Go to de2 software resources and click on altera de2 demos (http://users.ece.gatech.edu/%7ehamblen/de2/de2_demonstrations) than you will see some example projects for the DE2 board. Try de2_i2sound/ (http://users.ece.gatech.edu/%7ehamblen/de2/de2_demonstrations/de2_i2sound/) if it works with audio-in and audio-out, try to add your LPF stuff and check again. You can try to change the project regarding the I²C stuff, too, so you will be able to configure the WM8731 as you like. Hope it helps!- EGuer106 years ago
Hi, I am interested in these links, but they are broken. do you have any information?
