YADLE
6 years agoUsing the same Flash (EPCQ) for programming the device and for general use.
Hello, My design is using AS-Active Serial for programming cyclone V E . Can I use the same Flash (EPCQ) for two actions ?? : 1.Programming the FPGA 2.For general FPGA use I am in the middle ...
NurAiman_M_Intel
6 years agoHi YADLE,
AS_DATA0, AS_DATA1, AS_DATA2, AS_DATA3, and nCSO is a dedicated pin which means that the pin is for the specific function ONLY and cannot be use for other function. Hence you cannot used the same Flash for two actions in this case.
Thank you.
Aiman
