14 years agoUsing SignalTap II without JTAG?
Hello, I have board where I can't connect to the FPGA's JTAG pins. Nevertheless, it would be nice to be able to use the SignalTap II tool to have a look what is going on inside the FPGA - a Cy...
14 years agoMy general opinion about the problem: A board without JTAG connectivity is wrong from the start.
Particularly, there are two points aigainst your intention: - You would need to create a connection between the Quartus JTAG stack and your custom interface, but the Quartus JTAG stack is completely undocumented. - You would need to modify the virtual JTAG hub, but it's protected IP.
