14 years agoUsing SignalTap II without JTAG?
Hello, I have board where I can't connect to the FPGA's JTAG pins. Nevertheless, it would be nice to be able to use the SignalTap II tool to have a look what is going on inside the FPGA - a Cy...
14 years ago --- Quote Start --- No, I am afraid I can't change the board, so interfacing to the FPGA's JTAG through "neighbouring" pins is not possible. --- Quote End --- Make a note for next time: "Always make the JTAG pins accessible". You can't get to the pins at all? Is the FPGA in a BGA, what about vias on the bottom of the board? What about the TCK pull-ups/and downs you should have put on the PCB? --- Quote Start --- It's a shame that SignalTap II is not more flexible on the PC communications interface... at least I can't think of a good reason why there should not be an option to have the SignalTap II's interface ports be accessible by my top-level module instead of hard-wiring them to the JTAG port. --- Quote End --- The communication to the component is based around the JTAG HUB, and the communications infrastructure in Quartus uses the JTAG interface. It would be too hard for Altera to support a generic interface. --- Quote Start --- I have seen there is a Virtual JTAG megafunction, could that be an option to access the "real" JTAG pins from a FPGA module? --- Quote End --- Nope. You can never get to the real JTAG pins. The Virtual JTAG interface is how you get JTAG-like signals inside the FPGA fabric. However, those signals are controlled by the real JTAG pins, via the USB-Blaster. Cheers, Dave
