Using SDRAM on a DE2
Hi all,
I'm rather new to FPGA development, and Im having trouble finding a megafunction for the SDRAM for my DE2. I see there is something for it in the SOPC builder, but that's no help to me as far as I can tell. Im a little confused that there is nothing included from Altera for this purpose. What would you do to instantiate an SDRAM controller? Thanks, - John14 Replies
The DE2 kit should come with a CD full of demonstrations. The demo titled "DE2_TV" utilizes a 4-port SDRAM controller, which isn't generated by the SOPC. I've been using it the same situation you seem to be looking for (hardware circuits, no NIOS processor).
The SOPC Builder core is here: http://www.altera.com/education/univ/ip-cores/unv-ip-cores.html
Thanks, --Steve - Altera_Forum
All,
Altera provides a library of SOPC Builder components (IP cores), which are listed in the URL below, for all I/O devices on the DE1 and DE2 boards. These components can be used as part of the SOPC Builder tool in the Quartus® II software. They allow users to easily create Nios® II systems that can access the I/O devices on the DE1 and DE2 boards. Also provided are the associated software drivers that can be incorporated into an Altera® Debug Client project (or an Altera Nios II IDE project). http://www.altera.com/education/univ/ip-cores/unv-ip-cores.html --jmv - Altera_Forum
Yes, I took a look at that controller. It was hard to understand how to use it, since there is little to no documentation with it. I've never worked with SDRAM at such a low level before, so I need to keep it simple :P
The reference controller looks as if it will work fine for my purposes, and the whitepaper that comes with it is very informative. I may even rewrite it a little, since I will only be using page bursts (so as to maximize the throughput). - Altera_Forum
Hi, I don't have a DE2 board, but I assume you can just use the generic Altera SDRAM controller which comes with the niosii eds (https://www.altera.com/support/software/download/nios2/dnl-nios2.jsp), have you tried that?
Even with the evaluation version of the NiosII EDS, the SDRAM controller is fully working and not limited in any way. - Altera_Forum
Thank you Enrique! It looks good, I think this will do nicely. Thanks to Bee Gee A for finding it to begin with too :)
I can't really make sense of the controller generated by the sopc builder. It's not documented very well.
I still cannot connect to the reference controller at ftp.altera.com either... Seems to be exactly what i am looking for though. I can't start work on the rest of the project until I have an controller to use either. If anyone can connect to it, https://www.altera.com/servlet/download?swcode=www-ref-ssc-11-pc-vhdl&referer=https://www.altera.com/support/software/download/refdesigns/sdram-controller/dnl-sdr-sram.jsp I would really appreciate it if you could email it to me. - Altera_Forum
Thanks, that looks promising. Unfortunately the code files will not download, although maybe they will later on. ftp.altera.com seems to be down right now.
I searched Altera's site too :p I think the DDR megafunctions are no good for the SDRAM.
Don't want the NIOS, i'll be implementing the algorithms as hardware circuits. You think it would work if I created the NIOS with an SDRAM controller in the SOPC builder, then use the VHDL code for the memory controller which the SOPC builder spits out?
