15 years agoUsing SD-Card reader on DE1 board (with Nios)
Does someone know how could I include an sd-card controller to a nios II project in qsys? thanks
13 years agoI ran into the same problem using the latest 12.0 IP for QSys:
Error (12006): Node instance "packet_memory" instantiates undefined entity "Altera_UP_SD_Card_Memory_Block" Warning (12019): Can't analyze file -- file HostSystem/synthesis/submodules/Altera_UP_SD_Card_Memory_Block.vhd is missing I had to manually copy the following files from the IP directory to my Qsys synthesis directory: Altera_UP_SD_Card_Memory_Block.bsf Altera_UP_SD_Card_Memory_Block.cmp Altera_UP_SD_Card_Memory_Block.vhd From: C:\altera\12.0sp2\ip\University_Program\memory\altera_up_sd_card_avalon_interface\hdl To: <QsysProjectFolder>\synthesis\submodules
