15 years agousing ram simply
hi everyone, i'm working on a basic computer architecture. i want to use a ram without any clock just read and write on it.and specially my memory is 4096*16 bit. i'm working on max plus II
15 years agoHi Everyone,
I'm using ALTERA DE1 Board series of EP2C20f484C7N . in this board how to define RAM Memory Blocks using QUARTUS II (version9.0).... following program is what I've written , please help me about any correction library ieee; use ieee.std_logic_1164.all; entity simple_dual_port_ram_single_clock is generic ( DATA_WIDTH : natural := 8; ADDR_WIDTH : natural := 6 ); port ( clk : in std_logic; raddr : in natural range 0 to 2**ADDR_WIDTH - 1; waddr : in natural range 0 to 2**ADDR_WIDTH - 1; data : in std_logic_vector((DATA_WIDTH-1) downto 0); we : in std_logic := '1'; q : out std_logic_vector((DATA_WIDTH -1) downto 0) ); end simple_dual_port_ram_single_clock; architecture rtl of simple_dual_port_ram_single_clock is -- Build a 2-D array type for the RAM subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0); type memory_t is array(2**ADDR_WIDTH-1 downto 0) of word_t; -- Declare the RAM signal. signal ram : memory_t; begin process(clk) begin if(rising_edge(clk)) then if(we = '1') then ram(waddr) <= data; end if; -- On a read during a write to the same address, the read will -- return the OLD data at the address q <= ram(raddr); end if; end process; end rtl;
