11 years agoUsing OpenCore Plus IP (Triple Speed Ethernet) in Quartus v13.0 subscription edition
I was given a Quartus II project that makes use of Altera's Triple-Speed Ethernet MegaCore Function IP. The project was originally written in Quartus II v13.0 (subscription edition). I have the sam...
11 years agoI see -- thanks for clarifying. I also found this page helpful:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12202011_654.html which specifies how to deactivate the EDA Netlist step in the compilation: --- Quote Start --- To avoid this error, disable the EDA simulation tool in your project by opening the Settings dialog box from the Quartus II Assignments menu. Select the category EDA Tool Settings and the subcategory Simulation. On the Simulation page of the Settings dialog box, change the Tool name option to <None>. --- Quote End --- For reference, I found that Triple-Speed Ethernet is part of the MegaCore IP library and that --- Quote Start --- For MegaCore functions, the untethered timeout is 1 hour; the tethered timeout value is indefinite --- Quote End --- (from https://www.altera.com/en_us/pdfs/literature/ug/ug_ed8b10b.pdf)
