Using memory other than EPCS/EPCQ
Did you try to create a memory test project. This project helps to make sure that the memory is responding fine with NIOS II.
Here are some useful design examples:
https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/board-update-portal-utilizing-epcq-flash-memory-reference-design/
https://fpgacloud.intel.com/devstore/platform/17.1.0/Standard/boot-from-epcq-serial-flash-example/
Regards.
HI,
I do double check everything but it doesn't work. I add FIFO memory to the reception part and now it is much much better.
Another question is that "Do you know how can I cancel scanf(..) function?"
To explain this question I can say:
Intrinsically SCANF() function waits for ever till it receive a character. I need to wait for user input until certain amount of time; Hence, I run a timer and after timeout I want to cancel the scanf.
after timeout other thing working good but UART locks and does not work (I think it is due to ongoing scanf).
Any suggestion is welcome...
