ASeif
7 years agoUsing memory other than EPCS/EPCQ
Hi, I was wondering if anyone know that W25Q127JV memory is compatible with EPCQ128? I use NIOS II and Serial Flash Controller II. This controller can read memory but it fails to perform a write pr...
HBhat2
Contributor
7 years agoHi,
Some years ago I was trying some similar operation using some equivalent serial flash than EPCQ. At that point, I observed similar issue of NIOS getting hanged or operation failure. I remember that, when NIOS performs the operation (write/read/erase), it initially checks for the Silicon ID in the Serial flash. This silicon ID differs between EPCQ/EPCS to that of other serial flashes. As the Silicon ID differs for other serial flash device, the NIOS halts/hangs with that operation.
With Regards,
HPB
