12 years agoUsing full memory of Cyclone V
Hello
I am using a Cyclone V board and I am trying to create a large matrix. I am using the Altera-SocFPGA-HelloWorld-Baremetal as an example. However I do not have enough memory. How can I configure my code so that it uses all the memory available on the board? Thanks.1 Reply
Is 3 Hello-BareMetal examples in SoC EDS: with suffix "-ARMCC", "-GNU", and "-Linux".
In last may be is no troubles, Linux see all, or 1st and 2nd have only 64 K hi onchip RAM for using for program and data. Need add 256 M of system DDR3 to these system scripts scatter.scat and .ld respectively -- examples may be found nearby with big code, initializing of DDR3 make Preloader from included .ds-script. Use malloc() for get memory instead allocate it in program stack. Or may use other examples for add their functionality! :)
