16 years agousing fpga output pin as enable
Hi, I'm trying to use an FPGA output pin (through a pin header) as an enable for a switch. I've noticed that when the enable is "low", it's voltage is actually around 0.13 V with respec...
16 years agoBe careful, there is no guarantee that it will stay that low on all the temperature range. As FvM said, if you want to ensure a low voltage, use an external switch. Don't rely on any adjustable parameter on the FPGA.
