16 years agousing fpga output pin as enable
Hi, I'm trying to use an FPGA output pin (through a pin header) as an enable for a switch. I've noticed that when the enable is "low", it's voltage is actually around 0.13 V with respec...
16 years agoK, thanks for the tip. I tried a stronger drive strength and that brought it down to 0.07 V.
