17 years agoUsing differental input buffer as comparator
Hi, I'm designing a system using comparators to signalize analog signals, I wanna know that can I use the differental input pins on FPGA as comparators? If it is possible, the PCB will be smaller ...
17 years agothanks,i've see the data sheet, and the working condition is within the diff io feature. i'm going to test the differental io pins by some analog signals like sin or triangle, to see if it works.
